ramp runs
Control de lanzamiento
Discusión y preguntas relacionadas con el curso Control de Lanzamiento
1190 Vistas
is it normal and if so, why does the graph not increase smoothly why is there drop outs slightly as the rpm increases usually ramp runs increase in a smooth linear way that ive noticed
thank you
Since I don't know what particular graph or issue you are looking at, this is all a guess...
The X-axis of a graph will usually be either speed or time. If you have a graph of Engine Speed (RPM) vs. speed or time, it should be a straight line, however if there were an error in reading the Engine Speed (crank sensor noise, bad wire, etc), then however the Engine Speed is detected might show a lower value (or no value) for a short period.
Now if the X-axis of the graph is Engine Speed (RPM), then missing torque/power data might be due to some other issue with the dyno, or the tune (perhaps there was a huge drop in torque due to an ignition / fuel cut).
I'm afraid you'll need to show us the graph you are talking about.
