Analyzing crank position sensor and cam position sensor capture.
265 Vistas
Guys, can someone here comment on my capture?
I have included a screenshot and have several questions regarding what I have found.
This is for a Volvo B6304T (Inline 6, Turbo). The crank signal is variable reluctance obviously. I see 60-2.
The intake cam signal is a hall effect and seems to trigger twice each 720*. Would either of the pulses indicate the duration of the valve lift? If so, that would be the first window and not the second window that I have marked on the waveform, correct?
This is a monolithic engine and therefore, I am not sure how I can easily find the first TDC angle. I am hoping that it can be done analytically with the capture.
Also, I have wired this to an EMU Pro 8.
Thanks for your time in advance,
Greg
  • Los archivos adjuntos solo pueden ser descargados por miembros Gold de pago. Lea más sobre cómo hacerse miembro Gold aquí.
Since you have access to an oscilloscope, my suggestion is to fit a pressure sensor into cylinder 1, and remove all other spark plugs. Then you will be able to tell approximately when TDC of cylinder 1 is relative to your crank sensor gap. Your CAM trigger will end up being fixed offset, and you will likely need to choose a low numbered tooth crank to sample the cam sensor and determine which phase of the engine is active. Not sure how you set that up in the EMU Pro 8 -- hopefully the documentation will help you, or you can send that new scope capture to ECU Master for their expertise.
Good Luck!
David,
Thank you so much! I went straight out and built a pressure transducer. It isn't the best because I don't really have the right adapters (so it leaks a bit under compression). But I did manage to get a definite pressure spike indicating TDC on #1.
I am going to go get the Hantek and hook it up now and see if I can get a full Intake/Exhaust/Crank and TDC read from the hardware.
Normalmente respondemos en un plazo de 12 horas (a menudo antes).
¿Tienes problemas con el sitio web?
¿O necesita contactarnos por algún otro motivo?
