Anti Lag Valve
Fundamentos de la aerodinámica
Discusión y preguntas relacionadas con el curso Fundamentos de Aerodinámica .
1415 Vistas
We have a lot of problems with the flow of goods in Europe, and large shortages in deliveries. Therefore I wonder if I can use a wastegate valve as ALV ??
Would a DBW Throttle body be any use for you ? Since you are also in Europe you could get something small out of a VW Polo or even a bypass TB that the Golf GT (suercharged/turbo) has to interact between the 2 .
