2JZ build following HPA courses
Fundamentos de la alineación de ruedas en los deportes de motor
2459 Vistas
Hey Guys,
Having my first attempt at rebuilding a 2JZ myself and will be following HPA's Fundamental and Practical Engine building courses. This 2J came out of my 95 MIKV which I will then have a go at tuning the AEM Infinity.
So far this is what I am working with.
Stock 2J block machined 0.5mm over with Stock crank polished
Wiseco 9.5:1 Asymmetric pistons with .200 wall wrist pins
BC HD rods with ARP 2000 bolts.
ACL bearings
Exciting stuff Rory, please keep us posted =D
So finally getting some more time to work on the engine. I measured my bearing clearances and this is what I found.
Again this is using ACL Race Std size bearings on a micro polished crank.
Mains ( in thousands of an inch)
#1 0.0021
#2 0.0018
#3 0.0018
#4 0.0015
#5 0.0016
#6 0.0017
#7 0.0017
#1 is a little on the lose side of factory specs - max is 0.0024, the rest are pretty good.
Big end (rod) bearings
#1 0.0023
#2 0.0025
#3 0.0025
#4 0.0023
#5 0.0024
#6 0.0021
These are a little looser than I'd like but only by 0.0002-0.0003. Max for std is 0.0031 so they are within factory spec.
Keep the updates coming
Hi- dont know if you have checked but on some popular engines 1 or 2 thou undersize shells are available - with this small difference you can mix and match bearing halfs to bring clearances closer to spec .
I'm doing a similar build but the motor is going in a s14. Good Luck mate! Cheers
