Flexi hone
1495 Vistas
Whats your thoughts using a Flexi Hone yourself for the final finish?
hello Des,
It depends on what you're working with and what you need to achieve.
I've always used and though of a flexi hone as more of a tool to deglaze bores that measure up within spec or as a precaution when fitting new rings.
If there's any ovality, distortion or concentricity issues then it'll need machine honing on a vertical or horizontal, Rottler or Sunnen type machine but your engine machinist should know what to do.
Saying that I have used a 3 stone hone followed by a flex hone on classic aircooled single bikes in the past where tolerances aren't as vital and we needed digging out of a hole but i wouldn't recommend it:-)
Thanks, busy with a TC Lancia and Guy Croft swears by them. He did my head.
Regards,
As Scott said.
