1g DSM Haltech Injector setup
Brake System Design and Optimization
Struggling to get up and running with my 91 Eagle Talon TSI. Using Haltech Elite 1500 with upgraded DW 880cc LOW IMPENDENCE injectors. I thought I was doing right by updating all of the injector manufacturers settings in the Haltech but I can’t get the car to fire. Ignition seems to be fine. I am now realizing that I had the Haltech setup for Low Z 1-3 OHMs and also have the factory Injector resistor pack still installed.
probably don’t need both of these. Am I on the right track with my thinking? I am new to all of this but do read a ton and have most of the HP courses under my belt. If I don’t need both the Haltech setup to run the Low Z peak and hold injectors plus the Resistor which should I stick with? Should I just delete the OeM resistor pack?
I don’t know if this is even an issue to start with. Maybe the resistor isn’t doing anything if the Haltech is already doing its job?
I guess asking the question is sometimes enough to get you to the answer. I removed all of the settings I had changed for the injectors and used the Haltech base map and it fired right up. I would still like someone's opinion as to whether I should delete the old factory style Resistor box and let the Haltech handle that or should I just leave well enough alone and go with it? This is not a street car, will be a totally dedicated circut track car.
It can be made to work fine either way. Sounds like you are getting it going.
