Did he mean direct spark there at the end and not waste spark?
Can you point me to the specific module? Maybe even a time stamp if you can and I'll check it out.
Thanks
In ignition drives around seven minutes
Ok I had a look at that module and I believe what I've said is what I meant. I'm talking about direct spark at the time and then say 'The advantage over waste spark is...' which is the point being discussed. Let me know if I've missed anything.
You are correct. I understood the concept and thought it was out of place but i just misheard it the first time. thank you for the reply
