I have used most of your courses to build rebuild a 2010 Audi S3 with upgraded component (too many to mention here). I'm using a syvecs S8 and following your syvecs tuning course. As the vehicle in the course is similar I was wondering if you would be able to share the map you used. I understand it will not be the same but I'm more looking for a example of the settings which you do not cover in the course. I'm specifically looking for the VVT settings I'm currenlty getting VVT limp mode and I think the base duty cycle is to high it is currently at 80%.
Hi Thys, I've attached a start file for you to look at. Please be aware that this car was running flex fuel and dual maps so there's a bit going on in there.
