I had to adapt the existing 350Z harness to the Infinity ECU and I am having trouble with the terminology. I am re-pinning the harness and not using a adapter harness. They must have 20lbs of unnecessary wire...
1. What is Charge Out Pressure?
2. Also I have found no pin that requires input from the oil pressure sensor. Only the power steering pressure. Possible misprint?
