Hi all,
Im all im Craig and im addiicted to carcaine.
In all seriousness now im from the manawatu in New Zealand.
I have joined up to increase my wiring knowledge and skills.
My current projects include;
A 2016 Almac clubsprint (lotus 7ish kit car). This is powered by a 1800cc NB8C mx5 motor with a gt2560r turbo strapped to it. Car is approximately 700kg so is a little lively. I purchased the car last year built by the previous owner and am now tidying it up. The wiring is mostly mx5 factory loom which has over 100 twist and taped connections (im still counting) ,there were 3 twist and tapes from the power supply to the main power feed to the ECU alone
hello and welcome Craig looks like you have a big job on your hands i wish you well
Regards Ross
