hello i have a 2015 ram 6.7 i have tuned the truck successfully for 4 in straight exhaust with no power added. now id like to start adding some power I have added 10% to charge air flow from 1800 to 2800 rpm this map and others are rpm to torque conversion that have a max of 1175 nm. but I noticed in all the torque to fuel conversion maps go out to 1475 nm is there any need to change this map since i have told the ECM in the accel to torque conversion map it can make more torque
