Hey!
I have a Lincoln Mkz 2.0T (Same exact engine setup as Focus ST/Fusion 2.0T/Mondeo 2.0T).
I've been tuning based on spark, adjusted my stoich/lambda, torque tables, reduced max rpm to 6200 for HPFP to "support" E40, and started dialing in the turbo values.
Only things I've changed so far are full Injen inlet/intake, and step colder plugs.
If anyone has any tips based on the datalog, or has experience with the engine, I'm all ears as I've been trying to get this thing dialed in as perfect as I can!
Thanks much!
