Forum » General Tuning Discussion » Nw throttle setup
Nw throttle setup
Page 1
can any one send me the setup of nw throttle 102 because i changed my throttle and bot its read 9% and when it reach 10% its off and and cant increase more than 9%
lsa hptuner
I can't help you with the info that you need sorry, however I will add to this thread that any time you're changing a DBW throttle body, and particularly with OE ECU reflashing, it's essential to have all of the required data to populate the tables in the ECU otherwise you risk at best poor performance and DTCs, and at worst, a dangerous car that can cause a potential loss of control.
Where should i change?
You should contact whoever you got the throttlebody from. If the information isn't available, I would not attempt it.
