Forum » General Tuning Discussion » toyota starlet engine
Page 1
can i run my Toyota starlet turbo 1.3 engine with Link g4 atom ? or should i changer the cam gear or what should i do and i any one have a base map can you send my the base map [email protected]
Thanks,
Hi Abdullah, yes you can run that engine but you will be limited on outputs. It's enough however for a simple engine like this. I don't really believe in base maps as more often than not you're relying on another tuner doing there job properly and this can result in problems being 'baked in' to the file. If you go through our Practical Standalone Tuning course you'll see that the 10 step process creates a base map specific to your application.
