Hi,
I have a project going where I need to spec an ignition coil.
It's a turbo charged 5 cylinder engine with a distributor on a motec M130 ECU.
Any recommendations on a specific one please?
I'm in the UK.
Thanks in advance
What did the OEM vehicle use?
I would probably think Bosch Blue coil, or Lucas DLB105 coil would likely be suitable, but you haven't provided much detail about RPM range.
The M130 can easily drive individual smart COP units. Are they any of those what were used for later versions of your engine that could be fitted?
