Forum » How to Degree a Cam » Measuring Piston to Valve Clearance
How to Degree a Cam
Page 1
Would making the head gasket thicker help instead of machining the valve pockets and using different connecting rods? Would that contradict the process you are trying to achieve?
Unlikely, but if you would elaborate on your thoughts and what they refer to?
