2015 BRZ Ecutec Base map?
Having a bit of trouble with a customers car, 2015 brz with a Kraftwerks Supercharger kit with high boost pulley, id1000 injectors, flex fuel through the rear o2 sensor, 4 bar omni map.
Any base files to start from?
ZA1JD00C with racerom.
Hi Thomas, sorry I haven't at this point done any flex fuel tuning so I can't provide you with a base map including flex fuel. I do have a base map for a Bullet Supercharger if that's useful to you but it runs stock injectors and pump gas. Can you give me a little more info about the specific problems you're having?
