When doubling PMU outputs does wiring harness have to be modified? I mean splice secont wire near PMU and add another contact to that output?
This was not mentioned in module. If that is the case I believe this is a crucial step to make.
EDIT:
Sorry, this was mentioned 2 min later in the video when talking about air compressor.
Yes, you need to modify wiring harness.
