Forum » Practical Diesel Tuning » Injection Timing
Injection Timing
Page 1
Hi can someone confirm please that in the attached photo that the negative numbers are before top dead centre thank you
Adam,
It looks like the data in that map is represented in ATDC, not BTDC like you're expecting. The (-) data is more advanced and would be an injection event starting BTDC. The (+) value is one more retarded, starting ATDC.
What vehicle is the map from, out of curiosity?
Nick
Thanks for the reply. It’s a stock map from a 2012 Mazda bt50. So a larger negative number would be advancing the timing? Also these numbers are SOI numbers?
That's correct from what I can tell. -10* would indicate SOI 10* BTDC
Nick
I´d like to add a little bit of wisdom here. Don´t believe every number in those maps. They have to be taken with a grain of salt. Not uncommon for the drivers (definition files) to be wrong.
