Hello,
Here you reach 1500, 2000, 2500 rpm with full open throttle using left foot braking or with help from the dyno?
Thanks!
You don't use the vehicle brakes on the dyno at all. The Dyno is providing the load necessary to hold the RPM constant (through it's own braking mechanism).
