Steering wheel button
Practical Transmission Tuning
Discussion and questions related to the course Practical Transmission Tuning.
Doesn't seem they have crimp style buttons, so is the other means to use the screw down or solder? I know solder is usually an "avoid if you can situation", but don't know how well the screw down terminals will work being on a steering wheel. How do you guys wire up a steering wheel control?
We use Otto push buttons that have solder terminals, we have custom machined barrel nuts that provide protection for these solder connections, then I fill the back with silicon. The barrel nut allows either a removable 90-deg rubber boot, or a Raychem heat shrink boot to be easily fitted.
Here are a couple of pictures of a the buttons (include a toggle switch with screw terminals) that has been in service for almost 15 years. This was before I was using boots on the back, but it shows how I fill them with silicon, and what the nuts look like.
Nice, we will be using the OTTO P5-3 I believe. What boot do you use for the OTTO Push button?
I use this RB-290 boot. It's a bit of a stretch (ie, wait for your silicon to fully cure before stretching this over the back).
RB290 Boot Link
That's some lovely stuff David! I've used a similar technique in the past, but with APEM flat front pushbuttons that would accept a hard wearing sticker. The custom nuts on the back and the potting are a great solution.
