need some help after installing a ford motorsports hod rod cam set in my 4.6 3v mustang per the instructions set it is calling for a camshaft timing correction in the ecu calibration i have a hp tuners program but looking through the available maps i do not see anything that looks like the timing information in the camshaft manufactures instruction sheet. the callout for timking is 7* retard at 500rpm vrs. 0 for the oe camshafts and so on i can comment more on the total timing but my question is where in hp tuners might i look for the map that relates to changing the camshaft timing? any help would be appreciated
