As with tuning via HP tuners do you have the aftermarket lambda sensor going into scanner or is it reading the factory sensor and how do you set this up relative to the commanded EQ ratio?
The stock sensors are narrowband so these can't be relied on. We use an Innovate LM2 which connects to the HP Tuners interface but you can use pretty much any wideband you like.
