What should be afr engine with turbo?
Depends...
Fuel, EGT, etc, will maybe give some idea where it should be, but the only way to tell will be to load it and see what the engine tells you it needs.
If you go to a tuning shop and they tell you it has to be a set value, I'd suggest looking elsewhere.
