Drive DCCD with Link G4+
Understanding AFR
Hello tuners,
I’m planning to run DCCD center differential with Link G4+. After some research I assume Aux Out (GP PWM mode) can achieve this goal. DCCD is nothing but a simple electrical magnet driven by 12VDC. According Subaru repair manual, DCCD maximum voltage should be 6-7VDC, which mean duty cycle at approximate 50%. DCCD has 10A of operating current so I want use solid state relay to drive it. Here is my question:
1.DCCD has 6 different lock percentage, minimum is 15%. So the magnet may need low voltage right? Something like 1.5V or so? But ETA ESR10 SSR(I intended to use) only has 6-16VDC operating voltage. So it may not run DCCD low lock percentage properly right? If so, how about use CrydomD1D20(1-DC Series)? It has 1-72VDC operating voltage range.
2.D1D20’s datasheet said inductive load need to connect a diode. What is diode choosing direction? Current? Is IXYS DSEP60-06A a good choice? It has 60A average forward current.
Thanks,
Bruce
Hmm not sure on what's needed in between the ECU and the diff but I know for sure it has been done.
Dtech motorsport (David) would possibly the best guy to contact
https://www.dtechmotorsport.com/contact
Regards Ross
