2jz swap in gt68
Fundamentos del ajuste de EFI
624 Vistas
hey every one I'm going for swamping a 2jz vvti using link 4x fury but I'm very curies about using input and output from engine ecu,as its has gm external map sensor and e-throttle plus its will be street legal that means i have to make the ecu be comparable with Toyota can bus circuit
my issue is i need wiring sample so tat i can compare mine to make sure tat I'm using the right input and output
  • FuryQuickstartGuide-1.pdf
Unless you intend to reverse engineer CAN bus yourself, I'd get in touch with Link directly since that seems to be a key element of your project.
Their GR86 plug in unit documentation may have wiring info that's helpful to you as well.
