Aem V2 Honda Box ON 1JZ (DriftMotion Mod)
Fundamentos del ajuste de EFI
400 Vistas
Does anyone have a base file or cam/crank settings for an AEM V2 Honda box that’s modified by DriftMotion for a Non VVti JZ engine?
Running into an issue where a vehicle is hitting a cut at 3500RPM sometimes 3900RPM. Ignition timing in the software stays stable, none of the limiters are coming on, and zero sync issues when it happens. Using AEM Coil output 7&8 for cylinders 5&6.
