AutoCal vs Flashscan
Fundamentos del ajuste de EFI
1287 Vistas
I’m looking to start tuning a few trucks but not sure where to start. I’m not sure what real differences are between the flash scan v3 and autocal v3 so unsure about what I need to get. Thank you
If you're looking to make edits yourself you'll need a V3 or similar. If you're looking to have another tuner build files for you so you can install them in yours/customers trucks then an autocal will work just fine.
Does this help clarify?
Nick
Yes, thank you Nick
