Dynamic Airflow, MAF vs SD
Fundamentos del ajuste de EFI
1416 Vistas
On your worked example for the big cam Commodore, you have switched from MAF to speed density. On the Dynamic Airflow tab, if running a more moderate cam upgrade and keeping the MAF, would changing the High RPM Disable/Re-enable above redline still apply so it transitions from closed loop directly to the PE tables?
Dynamic Airflow is the transition from "Low Speed" Speed Density to "High Speed" MAF, If youre running a maf and set the dynamic airflow to an unreachable RPM - It Simply will not use the MAF.
Closed loop will still operate using the VE/VVE Table and PE Table will continue to rely on that as well.
