English - Spanish translation with IA
Fundamentos del ajuste de EFI
353 Vistas
The course EFI Tuning Fundamentals is in English and Spanish translated by AI.
Is it possible to translate more courses into Spanish with AI ?
It would be of great help to those of us who do not speak English.
Thank you
Hey Victor,
That is the plan! We're still just working on the system to make sure the team is happy with how it works and that it is at an acceptable level of quality which is clear and concise without causing confusion.
Another member also pointed out that not all tuning software (well, probably none to be honest!) actually translates everything over to Spanish, so we will work to add some resources where possible to help with that consideration (similar to how there is an anconym 'translation' sheet for the German tables in a Bosch ECU via the WinOLS course).
Hope that is good news for you and please if you think there is anything we could improve on during this process do let us know (ideally via support@hpacademy.com) as we are working hard to do this right rather than half assed =)
