Eurodyne Maestro: 2 Step trouble.
Fundamentos del ajuste de EFI
2556 Vistas
I'm looking for some input from anyone but more specifically from someone with experience with the software. I have a 2.0T FSI engine. I have the 2 Step option enabled. Activating it enables a clutch activated rev limiter (Which I have set to 4000 RPM) only with no timing retard.
Has anyone ran into this issue in the software? I've herd of some 1.8T guys just enable it and it does retard timing upon activation.
Sorry I'm not familiar with that particular software. Are you saying that you want retard and it's not occurring?
Yes, correct .
It's all sorted though. I contacted Eurodyne and was notified that 2step does not retard timing. it's just ignition cut .
Thanks man.
Glad you got to the bottom of it!
