Fuel trim problem indication
Fundamentos del ajuste de EFI
575 Vistas
Hi guys,
I found a guy on YouTube claiming that fuel trims up to 20% is acceptable and actually stated that one of his references is High performance Academy!
I never came across such thing in any of the videos.
What would be an acceptable % and what not?
Also do you combine both short and long term?
Thanks George
yes George you combine both of them as Andrew told us . An acceptable % in my opinion and as far as i remember would be [+-] 5%
Thank you for your response.
I always was allowing a maximum 10% combined.
Sounds like the limit should be lowered a bit..
Thanks again
You are welcome my friend. Don’t be afraid it’s not a big deal to decrease it . In a magic world the perfect would be 0% but it is very difficult to achieve so a 5% [+-] is ok
