Fueltech Injector staging
Fundamentos del ajuste de EFI
1415 Vistas
Sorry for the stupid question but the fueltech ft450 gives me two maps one for the primary injectors and one for the secondary, I have the secondary’s coming In at 0 vac would it be normal to see the primary map back off at this point then both continue to rise? The reason I ask is the primary map looks like it has a huge dip and it doesn’t look right.
I personally don’t think this is right and I should aim to smooth out the transition, you can’t feel the change while driving. I don’t really have anyone local that could help so thought it might be best to ask here. Sorry for the stupid question.
not sure I could have the secondary’s come in any more gradual.
