Injector data help fic 1200
Fundamentos del ajuste de EFI
218 Vistas
I have some recently purchased fic1200h-d that i wanted to install. LS L96 TURBO E38 FROM 09 G8 GT I am currently running SEP 1000s and had some help online tuning those in. My problem is that when i put in the values that values font take like that maxed out or w.e so im sure some scaling will be need but im sure it was already scaled. I'll upload my NA stock injector cam file then my turbo sep1000 file. Last time i believe my issue was that i was in a different unit. i checked my units this time. the only table that went fully was the Offset table. I'll also upload the data sheet if they let me. Only changes are Offset and short pulse limit so far. Any help will be greatly appreciated. Injector data - https://cdn.shopify.com/s/files/1/05...x?v=1722006641
  • 240sx-Speed-Density-L96-Cammed.hpt
  • FICLINIC_1200D_GMDATA_HPTUNERS_WEBSITE.xlsx
  • L96-240T-FIC-1200H-D-Offset-and-SHORT-PULSE-LIMIT.hpt
  • L96-240T.hpt
