Ls harness loom/sheathing choices
Fundamentos del ajuste de EFI
1214 Vistas
I'm currently in the process of converting a stock 2003 chevrolet 1500 truck harness into a standalone harness for a street truck. My concern is that the main trunk section of my harness is most likely gonna be too thick for the largest Dr25 readily available which is 1", is there any larger substitutes I could use? Thanks in advance!
Prowire stocks 1-1/2 inch DR-25 and claims other sizes are available on request.
https://www.prowireusa.com/c-9-heat-shrink-tubing.html
