Motec M130 GPR Package Selection
Fundamentos del ajuste de EFI
611 Vistas
Hi to all.
I'm quite new in the Motec world but have fiddled with it quite a bit, but still very novice. I have recently bought a M130 with GPR firmware, and on the flash stick is a whole selection of Packages.
As I understand it these packages are somewhat engine specific. I would like to know which package would suit our application the best.
Our project car is a Ford Focus st, fitted with the volvo 5 cyl turbo engine, port injected. After market turbo and manifold, external waste gate.
These are the following features we would like use
Anti lag
Traction control
Boost by gear or by circuit layout.
Any Advise would be appreciated
GPR is intended for general purpose motorsport applications.
If this is what your M130 is liceneced for then this is the only package you will be able to send to it.
GPR does not have any vehicle specific integration so if your Focus requires CAN signals to be broadcast by the OE ECU for other systems to operate these will not be present.
