Table Resolution
Fundamentos del ajuste de EFI
Módulo relevante: Tablas del sistema de gestión del motor > Resolución de la tabla
22 Vistas
hi i want to ask why we need to add zones when we want to correct the AFR, why we do not just change the value at the point at the uncorrect AFR and when we have to add zones and which way is better add zones or change the value at the critical point
Hi,
What zones are you talking about?
Are those the ones from the picture attached?
