17 mustang to 18 intake swap imrc re program 5.0 coyote
Ajuste del control de levas variable
1018 Vistas
hello i have a 2017 mustang gt with the 5.0 engine i have a roush cold air intake comp motha thumper cams and just installed a new 2018 inatke with the plug and play connectors from VMP i was wondering if anyone has had experiance with tuniing the new intake for the imrc set up as it is not the same as the 2017 intake any help and advise would be apreciated
