Advice on CAN cable
Ajuste del control de levas variable
1114 Vistas
Hi,
Anyone knows brand and type for CAN cable (single twisted pair) AWG20 in spec55 or equivalent for motorsport use with a reasonable small outer diameter in Europe? Most industrial types are very bulky.
Thanks Dirk
If you don't want to just twist 2 wires together, you can take a look at the Military Spec no M27500 for cables.
Something like M27500-20SD2T23 would work, but it's a shielded cable.
Last page of this document breaks down how to read the M27500 MilSpec :
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Catalog+Section%7F1654025_Sec9_SPEC55%7F0313%7Fpdf%7FEnglish%7FENG_CS_1654025_Sec9_SPEC55_0313.pdf%7F074911-000
Hope it helps,
Frank
