AE86 Pop up headlight on Motec PDM 30
Ajuste del control de levas variable
1794 Vistas
Hello guys I'm trying to get pop up headlights to work with the motec pdm I have manged to get the headlights to pop up (and down) with the headlight main beam switch and to pop up(and down) with the high beam switch the problem I'm having is when combining the to two functions it goes crazy and the motor just constantly goes on..
Has anyone had any luck with this on there car any help welcome
Hi Lucky,
Posting your config will assist in getting help.
