I just need some info about the type of crank and cam position sensors of these BMW engines (Variable reluctor or Hall effect) and if it's workable with standalone ECUs:
M50 Non VANOS
M50TU
M52
M60
M62 Non VANOS
Thanks in advance :)
I haven't worked with a lot of BMW engines however the ones I have done seem to use a fairly generic 60-2 trigger on the crank with a reluctor pickup and a hall sensor pickup on the cam.
Particularly if you want to run a non VANOS engine, you shouldn't have any trouble configuring any mainstream standalone ECUs to run these engines.
Hi.
These are USA models. Hopefully no difference.
M50 NV
60-2 Magnetic crank, Hall sync
M50 TU
60-2 magnetic crank, hall sync
(crank offset is different than previous generation)
M52 (single vanos)
60-2 hall crank, frequency inductive sync
The frequency sync sensor is provided a fixed frequency from the ECU, and as the sync trigger passes it, it changes the signal somehow (amplitude?), and this is how the factory determins stroke position.
I swap this out with a M50 hall sensor which fits right in and works perfectly.
M52tu (double vanos)
60-2 hall crank, hall sensors for both intake and exhaust cam
M60 NV
60-2 magnetic crank, magnetic sync
M62 (with VANOS version)
Thanks a lot, i appreciate it.
Could you please tell me what are the trigger offsets of these engines?
Hi.
I suppose it would all depend which ECU you were using. But in terms of gap vs TDC #1 (+/- 360 if out of phase) I can do my best. These numbers should work with most ECU... but obviously I'd still check. They may be a few degrees out.
* = not sure
M50 NV
275*
M50 TU
30
M52 (single vanos)
30*
30
M60 NV
275*
275*
You can see there is an obvious trend.
Thanks.
I would always recommend simply finding the correct offset for your engine once you have it to a point where you can start it and run it. It's easy to do with a timing light and is really an essential part of the initial configuration anyway prior to tuning.
