Hi,
Does anyone know which blade to use for TXL wire when using the Ergo Elite wire stripper? Can I still use the same MIL-81044 blade (55-1987)? As far as I understand the core of TXL has the same diameter compared to Tefzel, only the jacket is thicker but softer, so should be easier to cut. I already have the Ergo Elite and I'm wondering if I need to purchase a different one for TXL wire.
Thanks!
You might have already given it a crack and found success with this?
Just in case not, it is fine to use this with TXL too in our experience.
