Inch Pound Torque Wrench Recommendations?
Ajuste del control de levas variable
1736 Vistas
Like the title states, just wondering if anyone has recommendations with an inexpensive torque wrench in inch pounds? Thanks!
I bought a couple of Eastwood electronic torque wrenchs last year and have found them to be quite nice. They seam well made, and are easy to use. And they arent super expensive either. Atleast comparing to other electronic wrenchs on the market.
I got a couple of 1/2". (1 for me and 1 for a friend) and also a 3/8". And im pretty sure they also do a 1/4" aswell.
No specific recommendations - the markets and products are quite different here - but I would suggest you look at the upper range of the 'wrenches so there is some overlap with your next size up (3/8") torque wrench.
