M Overrun Brap (not pops) on regular F3x N55 like M2 N55 has it
Ajuste del control de levas variable
1555 Vistas
Hello, im trying to achieve M Brap like it is from factory on all F8x M cars (M2 N55, and S55). Can someone check what i did wrong on this file? Car shut off engine after reving.
I want to achieve this: https://youtube.com/shorts/2VFeKC_hg9Q?feature=shared
The car is f30 335ix PWG
  • v106-stage2-93oct_98ron.bin
  • WinOLS-v106-stage2-93oct_98ron-SAS-SPORT-BRAP-V1-BMW-3-Serie-Sedan-305PS-N55B30M0-Bosch-MEVD17.2.S-.bin
what XDF so I can take a look at this for you? Is it 98G0B?
It's 00001C41279601. Here is link for xdf https://mega.nz/file/wIo1hZTI#7ohUmKFCRl0imJeaszrU4McokA9sm1fPXAGT9GdqSJs
And same xdf is in attachment but you need to remove .pdf
  • 00001C41279601.xdf.pdf
