Hi guys,(sorry posted in wrong forum)
I have a turbo 1uz in a 4x4 that im adding a selectable crank driven Hydraulic pump-
which will be underdriven at approx 50% engine rpm.
The pump has approx 2500rpm limit.
Engine is controlled via a older link g4 extreme.
Which method would best to set as a 4500rpm limit while pump enganged?
Have a DI set with the on switch, looking i see theres a gp rpm limit in the "limit" tabs
set table to 4500rpm in all windows and active with DI1?
Yep GP RPM limit would do it fine, or you could use launch control mode 2 if you want to keep the GP limits for engine protection uses.
