ford 4.6 hp tuners setting up tables for maf and spark logging help
Ajuste y optimización de la suspensión
684 Vistas
After watching the ford worked example I am trying to setup my scanner for logging a ford 4.6l for my mustang and want to log my maf error so I can adjust the maf reading however it is in airflow vs maf voltage for the table in the file. Can someone help me with what to setup in the graph to log it correctly so I can apply the change into the tune file for hp tuners? Also need help setting up the spark one as well.
nevermind I got them from evans perf academy training.
