avgas fuel vs ratio
Análisis de datos de deportes de motor profesionales
Discusión y preguntas relacionadas con el curso Análisis de datos de deportes de motor profesionales
4831 Vistas
Hello,
do you have the ratio for AVgas fuel. ?... used from the normal single engine airplanes...
thank you
14.7; Avgas is just a leaded fuel.
Keep in mind that the lead WILL kill your lambda sensor pretty quickly.
Actually Avgas isn't just a leaded fuel. There are various grades and designations for avgas.
e.g. 100/130 is leaded (the lack of letters after the octane rating tells you this)
100LL is low lead
100UL is unleaded.
After a quick search, Avgas is available only at 2 places in Mozambique (Maputo FQMA and Villanculous FQVL) and distributed by BP who (as far as I know) only offer 100LL, so I doubt Silvio have a choice.
Anyway, UL or LL, the stoichiometric ratio remain 14.7:1.
