Discusión y preguntas relacionadas con el curso Análisis de datos de deportes de motor profesionales
hi all, can anyone tell me if there is an overrun fuel cut setting in the stock ecu of a Ford Fiesta 1.0ecoboost....
appreciate any help
dean
what are you using to tune it with?
It’s winols that will be used
thanks
There will almost certainly be an over run fuel cut strategy in the ECU but depending on your knowledge with winols, it may be difficult to find. There has been a lot of discussion back and forth about HP Tuners supporting the Fiesta Ecoboost. I can't confirm 100% if they can now provide support or it's still ongoing however if they can then this may be your easiest solution.
Thanks Andre.... we have found it but yes your right it was well hidden
thanks for your help guys
