Discusión y preguntas relacionadas con el curso Análisis de datos de deportes de motor profesionales
Hi all,
I'm trying to practise the skills learnt from the course and managed to found various map. The bin files used is from a Toyota Alphard 2.5 2ARFE with SW of 89663-58441. It is a Toyota newGen MCU D76F0XXX ecu. I have few questions that needs some assistance.
1) Has anyone know how does a Toyota Denso ECU flow works? i have found few maps that relates to torque and load but trying to link and make sense of them.
Torque Map
X : Pedal Position
Y : RPM
Z : Torque
Calculated Load (Air Load?)
X : Requested Torque
Y : RPM
Z : Calculated Load
2) Does anyone has a 2d snapshot on how does a limiter looks like on a Toyota Denso ECU? For Engine RPM limit and Speed limit.
Thank you
hi i did something on r7f7012 and i have a winols mappack + bitedit protocol for this ecu maybe we can understand somethinf from this? seems pretty similar
