duty cycle works backwardes
Cómo graduar una leva
2527 Vistas
Hi, i have a question? i have a haltech platinum pro ecu and i have problem with boost control.
my duty cycle works backwardes. and i want to know if i cant change it around?
And my openloop works but close loop does`t ,
That suggests your solenoid is plumbed incorrectly. Are you using a mac valve? how is it connected?
Yes i'm using a mac 4 port boost solenoid and it's plumbed in the car oem solenoid harness.
I did switch the wire of the solenoid around but it stay the same
As i increase duty cycle the boost drop off and when i decrease duty cycle boost increased
Yes, I understand what you mean, I wasnt asking about wiring, I want to know how the hoses are connected to the ports and wastegate. Give us a drawing or note down which port is connected to what. it sounds like you have the NO/NC ports swapped.
Solenoid ex port to atmosphere
Solenoid in to the turbo pressure
Solenoid A port to the top of the wastergate port
Solenoid b port bottom wastegate port
As said above, sounds like you’ve got the plumbing of the vac lines the other way round, however your example above seems ok.
Can you change the wastegate control mode in the ecu? I.e can you set it to Bleed On or Bleed off? This will also cause the same symptoms
Michael,
did you by any chance solve your issue, I am having a very similar issue. Hoping on your advice with this..
